1998 Chevy Lumina coolant leak
115,000 MILES • 6 CYL • 2WD • AUTOMATIC
WRING WORM
I have a 98 chevy lumina 3.1L and I noticed it began to over heat. I changed the thermostat and added an all make and model coolant. After allowing it to run in place then driving I noticed coolant leaking from the firewall when the car is turned off. I then noticed that the car engine calls for Dex coolant. Is this serious or could there be a hose of some sort missing that is connected to the firewall? All of the other hoses and connections do not leak except for an elbow looking connection on the firewall. What is causing the leak? If it is a hose, what does it connect to?
Mar 12, 2009 at 5:37 PM
  • 75,988 POSTS
You sure its not the heater core that's leaking?
Mar 13, 2009 at 1:22 AM
WRING WORM
No Im not sure. Also smoke comes into the cars vents after driving for 8-10 minutes. Could it be that the leak is due to a hose not being connected going back into the engine? I wonder if where the leak is coming from, can it be capped off closing the circulation?
Mar 13, 2009 at 3:59 AM
  • 75,988 POSTS
If there's an actual leak, you will see it-get the cooling system pressure tested to find where its leaking at.
Mar 13, 2009 at 10:40 AM
WRING WORM
I fixed the problem (temporarily that is). It was the heating core. I bought a "T" connector and by passed the heating core. That fixed the smoke and the leak. Thanks for your help!!! All is well!!!!!
Mar 13, 2009 at 5:53 PM
