Sorry for the mixup. My data shows only 2 pcs of 30 A maxi-fuse. None of the fuse was marked distrubutor in my database so can you please tell me the fuse # from the diagram, ( is it Fuse # 7, Direct Ignition System )? Btw to be sure I get the correct details, I need the engine variant of your vehicle as different engine variant has different wiring diagrams.
Fuse Identification
1 - 20 Amp Air Pump (3.4L Manual)
2 - 15 Amp Trunk Release, Back-Up Lights
3 - Not Used
4 - Service 3.4L DOHC V6
5 - Service 3.4L DOHC V6
6 - 4 Amp Injectors (4-Cylinder Engine)
7 - 10 Amp Direct Ignition System
8 - 10 Amp Injectors (3.1L V6 Engine)
9 - Not Used
10 - 15 Amp Ignition System
11 - 10 Amp Ignition
Relay Identification
12 - Air Pump Relay (3.4L DOHC V6)
13 - Not Used
14 - Heavy Duty Cooling Fan Relay
15 - Cooling Fan Relay
16 - A/C Compressor Clutch Relay
Maxi-Fuse Identification
17 - 60 Amp Starter Solenoid
18 - 30 Amp Cooling Fan (2.5L & 3.1L); 60 Amp Cooling Fan (3.4L DOHC V6)
19 - 60 Amp High Blower
20 - 60 Amp Cooling Fan
21 - 30 Amp Ignition
SPONSORED LINKS
Monday, June 24th, 2019 AT 6:47 PM
(Merged)
