2000 Chevy Lumina Bangs into gear and shakes while throwing
66,000 MILES • 6 CYL • 2WD • AUTOMATIC
THEKITTY
I have had the valve body with the pressure control solenoid replaced in my tranny as well as the torque converter. My car still shifts hard when its warmed up and makes the ever familiar whining sound. It shifts hard and the longer i drive it the worse it gets. It will literally slam into gear with a loud bang and give the car a good shake. when this all happens my check engine light will come on. The tranny guy says the transmission looks good inside and he cant find anything wrong even after replacing the torque converter and valve body. So all in all what are my other options for why my tranny shifts hard and bangs into gear when its really warm as well as making the car shake while it shifts and throws the check engine light. Fluid is fine, mounts are good, had work done on the tranny and still no good... help!
Jul 14, 2008 at 5:37 AM
DOCFIXIT
  • 18,828 POSTS
Why don't you check for codes this will tell what is happening when she bangs.
Jul 14, 2008 at 5:53 AM
THEKITTY
the codes thrown were what had been replaced valve body and the torque converter so thats why im at wits end it makes no sense
Jul 14, 2008 at 5:54 AM
DOCFIXIT
  • 18,828 POSTS
Need to know what they are now after repair.
Jul 14, 2008 at 6:02 AM
THEKITTY
understandable, was at the tranny guy this morn and it didnt read the pcs code which was what it did b4 thats why we replaced the valve body. then the second time it threw the check engine light and they replaced the torque converter for that. we play the waiting game for now till the light comes on ty tho
Jul 14, 2008 at 6:06 AM
DOCFIXIT
  • 18,828 POSTS
Go by an Auto Zone they will code then post.
Jul 14, 2008 at 6:09 AM
