1999 Chevy Lumina
MICHAELA LEE
  • 1999 CHEVROLET LUMINA
1999 Chevy Lumina V8 Four Wheel Drive Automatic
i have a 1999 chevy lumina, 3.8, and i've had my starter, and fuel pump replaced. The car will cut off on it's own, while driving, and kind of makes like a loud purring noise. After a few moments it will start back up. It's like it's not getting power to it. I don't know what else it could be a result of, mass air flow sensor going bad again, or the spark plug wires are going, or are bad.
Monday, February 15th, 2010 AT 1:30 PM
BASSTECH
  • 236 POSTS
It could be the crank shaft position sensor. They go bad sometimes when they get hot, then when it cools down they are Ok again. Not sure about the puurring noise. Does it sound like something is running?
Monday, February 15th, 2010 AT 4:54 PM
MICHAELA LEE
  • 6 POSTS
Thanks!I did get the new spark plug wires put in today, which I didn't do when I got the spark plugs changed. So I guess we'll see what happens. The person who changed them, did put it t on the code reader, and the only thing that came up was MIL solenoid circuit.
Monday, February 15th, 2010 AT 5:56 PM
BASSTECH
  • 236 POSTS
MIL usually stands for "malfunction indicator lamp" which is the check engine light circut. Does the check engine light come on when you turn the key on? If it dosen't than that's why that code is setting.
Let me know how you make out with the stalling
Tuesday, February 16th, 2010 AT 6:49 AM
MICHAELA LEE
  • 6 POSTS
No, the check engine light isn't coming on. When it did a while back, it was the mass air flow sensor that was bad. It stalled on me today. I don't know what is wrong at this point. The diagnostic machine isn't turning up anything.
Tuesday, February 16th, 2010 AT 12:21 PM
BASSTECH
  • 236 POSTS
Well if the check engine light isn't coming on that could mean one of two things. Either the bulb is burned out, or the computer is faulty. If the computer is bad, that will cause all kinds of stalling and other problems, and may not give you any codes in the meantime.
I don't like to throw parts at a car that I can't diag. Myself, but you may want to look into the crank shaft position sensor. Only because when they go bad, the car will stall and not start for a while, and they won't set a code in the computer on the older models like yours.
Also i'd look into the check engine light bulb, cause if the bulb isn't bad then you may have a computer issue.
Let me know how you make out with them and we'll take it from there.
Tuesday, February 16th, 2010 AT 1:54 PM
MICHAELA LEE
  • 6 POSTS
Thank you. Will do.
Tuesday, February 16th, 2010 AT 1:57 PM
