1998 Chevy Lumina overheating
TONYSOT
  • 1998 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 18,000 MILES
Thermostat replaced, no evident antifreeze leak, radiator flushed out
Tuesday, September 21st, 2010 AT 7:48 PM
Check the water pump if its doing job if okay -could be airlock in it -try bleeding it -don't work get it block and pressure tested-
Tuesday, September 21st, 2010 AT 8:09 PM
NICKHEADZ34
  • 62 POSTS
You may have bad coolant temp sender. This would keep your fan from cooling. If u drive in the city this may be your problem. Highway speeds can actually suffice to properly cool it.
Saturday, October 2nd, 2010 AT 6:17 PM
