1998 Chevy Lumina CAR OVERHEATING
SMOKEYS MOM
  • 1998 CHEVROLET LUMINA
  • 6 CYL
  • 132,000 MILES
IT STARTED WITH THE AC GOING OUT STILL WORKS JUST NO COOL AIR
NOW OVER HEATING BUT NOT BAD . NO LEAKS FUILDS ARE FINE NO SOFT HOSES COULD IT BE THE THEROMSAT
Friday, July 9th, 2010 AT 3:41 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Since no leaks, thermostat and cooling fans would be first to check out
Friday, July 9th, 2010 AT 3:44 PM
SMOKEYS MOM
Thank you I will try replacing the thermostat first. See if that is the trouble, I am a vet and not much money right now but I will make a donation at a later date, my husband a vet too just started back to work today and we only have I car between us, for now, so this is a big help. Our goverment dosent help much for unemployed vets. We have to sarcfice on our own. But we are still proud americans
Friday, July 9th, 2010 AT 3:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
It is fairly easy to test the thermostat, although they usually only cost around $5, you could just test it first before replacing. Just suspend it in a pot of water over your stove and use a thermometer capable of 200F + rating and watch to see when or if the valve opens.
Friday, July 9th, 2010 AT 3:58 PM
