1998 Chevy Lumina No crank condition / Alarm
DUSTYRUSTY
  • 1998 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 130,000 MILES
My car will not crank/turn over. I tried my second key thinking maybe the resistor went bad, but it still wouldn't crank. I jumped the starter with the key in the "ON" position and it started but would only run for about 3 seconds.
HELP!
Russ
Thursday, June 5th, 2008 AT 3:06 PM
MERLIN2021
  • 17,250 POSTS
GM PASS LOCK RELEARN- Ignition to "run" position, try to start and let key return to "run" position
Approx ten minutes security light will go off
Turn key "off" and wait 5 seconds
Repeat 2 more times for a total of 3 relearns.
Turn key off, then start it
Thursday, June 5th, 2008 AT 3:08 PM
DUSTYRUSTY
I did what you suggested but the security light would not go out. Even after 35 minutes.
It was flashing and the service manual said that there was a problem with the system.
What can we do now.
P.S. I am more than willing to pay you on the 18th to help get my car back on the road.
Russ
Sunday, June 8th, 2008 AT 1:33 PM
MERLIN2021
  • 17,250 POSTS
Checked all fuses? Even under the hood? Check connectors to security module and PCM GM's are notorious for bad connections. Try a different key. Then it's a trip to the dealer for testing, and reprogramming.
Monday, June 9th, 2008 AT 1:01 PM
DUSTYRUSTY
I don't know where the security module is to check the connections.
Russ
Tuesday, June 10th, 2008 AT 9:13 AM
MERLIN2021
  • 17,250 POSTS
PCM(Powertrain Control Module) isat the right stut tower, and the theft deterrent Module is behind the glovie!
Tuesday, June 10th, 2008 AT 1:48 PM
