I want to replace the fuel pump on my 1998 chevy lumina when I go to remove the fuel pump assembly on top of the fuel tank there is some plastic fuel lines attached and the only way to get them off is to cut them or may be heat them up but in need to know how to get them back on the new fuel pump assembly also.
could I cut them and then use just plain old rubber hose with some clamps.
Heat them so they will streach and come off then heat up again to put back on.
Is heating them up going to cause fire?
SPONSORED LINKS
Tuesday, June 17th, 2008 AT 6:09 PM
