OK first NO SMOKING OR OPEN FLAMES. Now simply disconnect the battery cables and then you drop the gas tank remove the old pump and replace it and put the tank back in and connect the cables and cycle the keys a few times to prime the lines and start it. I would also repace the fuel filter too if it has been a while. I get into more depth in instructions if needed but basicly that is it. Like I said as long as you don't smoke or have any open flames or sparks near by you will be fine. I have never had one blow up yet.
Apr 10, 2010 at 8:07 AM
