HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Engine
Symptoms
Not Running
SPONSORED LINKS
1997 Chevy Lumina WILL NOT START
XCNOTEDII
MEMBER
1997 CHEVROLET LUMINA
6 CYL
FWD
AUTOMATIC
150,000 MILES
STARTER WILL NOT ENGAGE WITH KEY BUT WILL CRANK AND KILL IF U JUMPER IT AT STARTER.
Monday, July 12th, 2010 AT 7:53 AM
INTERNETMECHANIC
MECHANIC
Does the security lite stay on? Passkey 2 is starter and injector disable.
SPONSORED LINKS
Monday, July 12th, 2010 AT 9:23 AM
XCNOTEDII
MEMBER
Malfunction Indicator Light is turned off when checking with ODBII tester. Security light continue to flash.
Monday, July 12th, 2010 AT 5:06 PM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
1997 Chevy Lumina Car Will Not Start Cause Security...
I Can Not Start My Car Cause When I Try The Security Light Blinks Which Will Not Permit My Car To Start. Is There Any Way To Reset The...
Asked by
janieh_1998
1 ANSWER
1997
CHEVROLET LUMINA
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
1997 Chevy Lumina Car Will Not Start. "security&...
I Was In The Process Of Getting Ready To Service My Car So I Unhooked The Neg. Battery Post. Before I Started The Work I Went To Hook The...
Asked by
jw20005
1997
CHEVROLET LUMINA
It All Started Two Months Ago When My Chevy Lumina Would Not Start. This Happen On A Saturday Evening. The Car Was Towed To My House. I...
Asked by
luvana01
1 ANSWER
1997
CHEVROLET LUMINA
Car Won't Start!
The Car Won't Crank I Turn The Light On And Not The Battery, Gas Pump Is Good, Could It Be The Ignition Lock Cylinder?
Asked by
yannicrisantos
1997
CHEVROLET LUMINA
No Start No Fuel In Cylinder
New Fuel Pump And Filter Good Pressure On Test Port Injectors Not Pulsing No Blown Fuses Crank Sensor Tested 900 Ohms And.5 Volts Ac When...
Asked by
tutter2367
1997
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
