1997 Chevy Lumina water going into engin
1997 CHEVROLET LUMINA
166,344 MILES • 6 CYL • FWD • AUTOMATIC
BSTEVEY10
the water goes right into the engin and then it ruins the oil, i need a oil change but i want to fix the problem with the water, y would there be water getting into the engin, could it be the head gaskets? If not what could it be?
Jul 11, 2008 at 9:08 AM
Could be headgasket cracked head or block and intake manifold gasket
Jul 11, 2008 at 9:16 AM
DOCFIXIT
  • 18,828 POSTS
Have you seen any white smoke from tailpipe?
If so headgasket failure If not bad intake maniflod gasket can introduce water to engine.A coolant pressure test will show which one.
Get this taken care of soon you run the risk of damaging engine bearings.
Jul 11, 2008 at 9:20 AM
