1997 Chevy Lumina STILL OVER HEATING
BABYGIRL71907
  • 1997 CHEVROLET LUMINA
Other Category problem
1997 Chevy Lumina 6 cyl Wheel Drive Type unknown Automatic 103657 miles
MY CAR IS SAYING IT IS OVER HEATING AFTER CHANGING THE THERMOSTAT AND WATER PUMP. THE RADIATOR IS NOT OVER HEATING THOUGH BUT GAUGE IS SAYING IT IS AND I AM GETTING NO HEAT. WHAT SHOULD I DO NEXT?
Saturday, January 5th, 2008 AT 2:11 PM
No boilover or gurgling on the front could mean that the gauge is out of calibration or wiring problem. No heat -might be a bad thermostat/clogged heater hoses/heater core/heater control valve.
Saturday, January 5th, 2008 AT 2:22 PM
BABYGIRL71907
I changed the thermostat also. I changed the radiator cap as well. Do you think it could be the heater censor that controls the temp gauge? If not what else could it be? Also it has alot of pressure when I took the radiator cap off and it was gurgling. We did flush the radiator with the proper stuff it had alot of sluge in it. Could I have a back up somewhere and if so where should I look first?
Saturday, January 5th, 2008 AT 3:59 PM
Try this-Bleed the cooling system see below and report back
Always bleed air from cooling system after replacing coolant. Set heater for maximum heat. Remove radiator cap. Loosen drain plug and remove drain bolt (if equipped) from engine block. Drain coolant reservoir. Fill coolant reservoir to MAX mark with 50/50 water-coolant mixture. Loosen bleed bolt and fill radiator up to base of filler neck. Close bleed bolt when coolant flows out without bubbles. Tighten bleed bolt. With radiator cap removed, start and operate engine to normal operating temperature. Add coolant if necessary and check for leaks.
Saturday, January 5th, 2008 AT 4:58 PM
BABYGIRL71907
Just wanted to let you know we bleed the two bleeder valves and now the car is running great so far. Thanks for your help
Sunday, January 6th, 2008 AT 12:14 PM
You're welcome and feel free to invite friends over, we'll be here waiting.
Sunday, January 6th, 2008 AT 2:44 PM
BABYGIRL71907
You all were a great help and believe I will refer you
Sunday, January 6th, 2008 AT 3:12 PM
