1997 Chevy Lumina?
MELIBEE
  • 1997 CHEVROLET LUMINA
Engine Cooling problem
1997 Chevy Lumina Automatic 150000 miles
Last three weeks, intermittently, hot engine light / heat gage going up temporarily, but no heat or steam in engine. Loses acceleration, check engine light coming on. Catalytic converter? In CA I can't get a free diagnostic.
Wednesday, May 6th, 2009 AT 8:28 PM
  • 109,936 POSTS
A converter will cause the car to both loose power and overheat. You need to listen for a ratteling, hissing, or note if there seems to be limited back pressure from the exhaust. You can also check for pressure at an upstream O2 outlet and check it with the downstream.
Don't the nationally recognized parts stores like Auto Zone, Advance. Scan for free?
Friday, May 8th, 2009 AT 12:14 PM
MELIBEE
Thank you for your response. Had a friend run a diagnostic today and code said either map sensor or pedal sensor. And no, most auto parts stores no longer do the diagnostics, at least here in CA. I think we're going to try throttle sensor first and then map :), and also flush coolant. Thanks again ! !
Saturday, May 9th, 2009 AT 10:36 PM
  • 109,936 POSTS
I'm sorry to hear that about the free scanning in Ca. They advertise it here in PA. Let me know what you find. I would like to know.
Sunday, May 10th, 2009 AT 2:01 PM
