HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Lumina
Fuel System
Fuel Pump
Replace/Remove
1997 Chevy Lumina fuel pump
GOOGOO2000
MEMBER
1997 CHEVROLET LUMINA
6 CYL
2WD
AUTOMATIC
100,000 MILES
How do I replace the fuel pump?
Saturday, August 2nd, 2008 AT 2:33 PM
BMRFIXIT
MECHANIC
Pump is located in the fuel tank
disconnect battery negative
raise and support the car
drain fuel out of tank
disconnect fuel lines and filler hoses
remove tank
remove pump
SPONSORED LINKS
Saturday, August 2nd, 2008 AT 8:08 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Replace/Remove Content
1995 Chevy Lumina How To Replace Fuel Pump
1995 Chevy Lumina 6 Cyl Automatic 200000 Miles I Have A 1995 Chevy Lumina Van Apv 3.1 And Need To Replace The Fuel Pump. How Do I Take...
Asked by
helga
1 ANSWER
1995
CHEVROLET LUMINA
GUIDE
Fuel Pump Replacement
When a fuel pump goes out it can do so one of two ways either it can quit and stop working or it can fail intermittently causing the engine to stall or not start.
1993 Chevy Lumina Fuel Pump Installed
I Replaced The Fuel Pump And Wiring Harness And Filter. You Can Hear The Pump When The Key Is Turned On. It Pumps Up And Shuts Off, But...
Asked by
Edwin Cann
1993
CHEVROLET LUMINA
1999 Chevy Lumina Engine Wont Start After Fuel Pump...
Fuel Pressure Was Not Released From The Injectors Before Tank And Fuel Pump Removal. Fuel Pump Is Working And Sending Fuel To Filter But...
Asked by
jb7386
1999
CHEVROLET LUMINA
1995 Chevy Lumina Fuel Pump Replacement
Wanted To Know How To Replace The Fuel Pump Which Is Inside The Gas Tank Without Blowing Myself Up.
Asked by
donjschulze
1 ANSWER
1995
CHEVROLET LUMINA
1990 Chevy Lumina Need Help Asap Please.
I Have Replaced The Fuel Pump, Fuel Filter, Ign Control Module, Coils All 3, O2 Sensor, Plugs And Wires. The Problem I Am Having Is This...
Asked by
mechanicmangg
1990
CHEVROLET LUMINA
VIEW MORE
SPONSORED LINKS
How to fix an engine that wont start
Engine Not Starting
Fuel Pump Pressure Test
Online car repair manuals
