i put my driver power window down and i can't get it to go back up i took the door panel off and checked the fuse box they where all ok then i went to take the plate that the motor is on and i hit the power button the window went down the plate that holds the motor moved and i can't move it back i took the screws out like a dumy so what can i do to take the pressure off and line that plate to screw it back
Jan 29, 2010 at 2:56 AM
