1997 Chevy Lumina
DM14469
  • 1997 CHEVROLET LUMINA
Electrical problem
1997 Chevy Lumina 187000 miles
all of s udden my running lights and my lights in back not working. Turn lights work, brake lamps work, all lights work except the parkink(running lights) I am at lose. Plz help if can. Thank you
Sunday, March 30th, 2008 AT 6:40 AM
BMRFIXIT
  • 19,053 POSTS
Turn lights on check fuses
Sunday, March 30th, 2008 AT 7:11 AM
BMRFIXIT
  • 19,053 POSTS
To: BMRFIXIT
Posted: Sun Mar 30, 2008 9:16 am
Subject: lights
i checked fuses and they all good but I did not turn on lights first. My dash lights also not work I am lost as it just started doing this yesterday after I put 4 ways on then off again
The reason for putting the light on is because the power goes throw the fuse and if the switch off
that fuse will show no power and its easy to over look
you may want to try that
Sunday, March 30th, 2008 AT 9:28 AM
THESMITTYGUY
Look under the hood at the relay/fuse box. It is probably full of corosion. Its on the drivers side underneath the cross bracket.
Good luck.
Monday, April 21st, 2008 AT 8:44 AM
