1997 Chevy Lumina
GIPSONJEFFREY
  • 1997 CHEVROLET LUMINA
1997 Chevy Lumina 6 cyl Two Wheel Drive Automatic
I JUST REPLACED STARTER AND BATTERY IS GOOD WONT START. ALL ELECTRONICS WORKS BUT ACTS LIKE ITS DEAD. WAT ELSE COULD BE WRONG
Tuesday, October 20th, 2009 AT 9:24 AM
I JUST REPLACED STARTER AND BATTERY IS GOOD WONT START. If you're talking about it cranks over and will not start could be fuel or spark problem do below to determine what's causing it
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor camshaft and crankshaft sensors- Note: If it doesn't apply disregard it
Tuesday, October 20th, 2009 AT 9:31 AM
GIPSONJEFFREY
IT WONT EVEN CRANK OVER, I TURNED CAR OFF THEN IT WOULDNT START TRIED JUMPING IT STILL NO START. TRIED TO BYPASS SOLENOID AND STARTER FOUND OUT STARTER WAS BAD, REPLACED IT HAD BATTERY TESTED ITS GOOD, WHAT ELSE COULD BE WRONG
Tuesday, October 20th, 2009 AT 9:37 AM
JDL
  • 16,098 POSTS
Welcome, possibilities-- theft system--neutral/transmission range sensor. Do you have a theft/security lite on the dash, is it on or flashing when trying to start? Can you tell if there is a load on the starter circuit when trying to start, watch the dash lites or dome lite when trying to crank, if the lites go out or acts-up, the starter circuit is closed.
Tuesday, October 20th, 2009 AT 9:39 AM
GIPSONJEFFREY
HOW DO I OPEN IT?
Tuesday, October 20th, 2009 AT 9:47 AM
