My 1996 Cherolet lumina Sedan temperature gauge began to climb more than usual, when i checked out the problem, i found that the radiator fan was not coming on. The one for the A/C works just fine and when I switch the fuses from one to the other, the A/C Fan still works properly. I have checked out all the fuses tha could possibly be linked that i know of, what route should i take next?? I don't want to go out and buy a radiator fan motor unless i know for sure that it is the problem.
Thanks
Thanks
Dec 12, 2007 at 9:02 PM
