1996 Chevy Lumina Brake Lights
JOHN ZIOMKOWSKI
  • 1996 CHEVROLET LUMINA
Electrical problem
1996 Chevy Lumina 6 cyl Two Wheel Drive Automatic
When I apply the brake pedal the brake light in the rear window lights up but the left and right hand brake lights do not although the passenger side did light for a short time. I have checked the fuse and the replaced the bulbs. What could be causing this?
Tuesday, December 23rd, 2008 AT 9:44 AM
DOCFIXIT
  • 18,828 POSTS
Fault is in turn signal switch most likely
Tuesday, December 23rd, 2008 AT 10:04 AM
JOHN ZIOMKOWSKI
Is the turn signal switch also known as the multifunction switch?
Tuesday, December 23rd, 2008 AT 11:14 AM
DOCFIXIT
  • 18,828 POSTS
Yes brake circuit runs through it so when brakes apply they overide turn signal
Tuesday, December 23rd, 2008 AT 12:33 PM
