No brake lights, third brake light works?
125,000 MILES • 6 CYL • FWD • AUTOMATIC
KSGARNER
I have no brake lights, but the third brake light is working. We replaced bulbs, fuses, but they still do not work. Any ideas of why?
Sep 6, 2010 at 8:44 AM
  • 75,988 POSTS
Test the turn and hazard switch. This guide will help
https://www.2carpros.com/articles/brake-lights-not-working
Sep 6, 2010 at 9:16 AM
HAGLERED
I have the same problem. My hazard lights work. Right works fine, left works when you hold turn signal arm in position.
Sep 14, 2010 at 2:36 PM
MYKEH7
Electrical problem
1996 Chevy Lumina 6 cyl Front Wheel Drive Automatic
are the breke light and flasher tied together. The left turn signal is fast and no brake lights
Aug 15, 2020 at 4:16 AM (Merged)
  • 110,248 POSTS
Hi:
The element in the bulb has a duel puropse. It functions for both the signal and the brake. Replace the bulb and it should fix the problem. NOTE: The quick flashing usually indicates a bad bulb.
Let me know how it goes.
MARY C-P
Electrical problem
1996 Chevy Lumina 6 cyl Two Wheel Drive Automatic
brake lights don't work. have changed bulbs and fuse.
BLACKOP555
  • 10,386 POSTS
does the thrid brake light in the rear window work?
PLOWE085
Electrical problem
1996 Chevy Lumina 6 cyl Automatic
My brake lights don't work unless i pull back on the turn signal how can I fix this ?
BLACKOP555
  • 10,386 POSTS
sounds like a bad turn signal switch. make sure you get a good part or a genuine part from a junk yard which is recommended.
if you buy new and buy a offbrand it will go out and you will be replacing it again.
junk yard is the way to go if you dont have the money
LITTLEAARON1
brake lights not working
BLUELIGHTNIN6
  • 16,542 POSTS
check fuse, bulbs and brake light switch below driver dash.
TOPCHEF
Electrical problem
1995 Chevy Lumina Two Wheel Drive Automatic 120000 miles
brake lights not working light up at back window is working though fuses are all fine
DOCFIXIT
  • 18,828 POSTS
Faulty turn/multi-function switch
TWOO46
I have a 1995 Chevrolet Lumina, the problem is my outside brakelight does not work, i tried the bulb, and fuse with no luck. The break light in the back window come on when i apply the brakes, but none of the outside brake lights do. The rear lights work when i turn on the headlights, but when the breaks is applied they do not come on. Thanks
BLUELIGHTNIN6
  • 16,542 POSTS
Suspect faulty stop light switch. Need to inspect stop light switch ( aka brake light switch) mounted above brake pedal arm. High-mount light is ran by a relay, the outer 2 brake lights are ran by the switch.
Thanks for using 2CarPros.com!
AMEISSNER
I have a 1995 Chevy Lumina V6 with 100,000 miles. I have a couple problems that may or may not be related. If I press the turn signal lever all the way down (where it locks in place), the signal light will not come on, but if I hold the turn signal lever down (not quite to the point that it locks in place), the signal lights will work. The main problem that I have though, is my outside brake lights don't work. I have tried the bulbs, fuses and wiring with no luck. The brake light in the back window comes on when I hit the brakes, but none of the outside brake lights do. The rear lights (same bulbs as the brakes) work when I turn on the headlights, but when the brake is applied, they do not come on. I am going to look into having the turn signal switch replaced and I am hoping that is what is causing both problems. Thanks!
MERLIN2021
  • 17,250 POSTS
Who know...with a shot accross the contacts in the multifunction switch, yes I think it's a good bet!
PWNMONKEY
I have the same issue with the same year Lumina.
The problems you described are the same as mine; brake lights not working with tail lights and such, except my turn signals dont work at all.
I'll re-post if replacing the switch corrects the problem, I can't see what else it could be.
PWNMONKEY
okay, so I pull out of the shop yesterday after posting the above, and when I flip the right turn signal - IT WORKS.
I tried the left signal and it only worked for me when I gently pushed it down and it would not stay activated while locked in place. Sometimes the right signal will not lock in with the signal activated, and has to be held as well.
I replaced the two tail lights before I even took apart the steering column, so I am wondering what had more to do with it. Obviously the switch is bad (apparently a shop rumor that these things happen with GM's of that simmilar make and year.) I did not replace the switch, I put the old one back to save a little money for the holidays since I can now signal.
D PALMQUIST
Same problem with my 1996 Lumina sedan.
If I put the turn signal in its locked position, the in-dash signal indicator blinks rapidly, which would normally indicate a burnt-out bulb. However, if I hold it slightly out of position, it works fine.
The cruise control stopped working for a few months. Its switch is part of the multifunction switch. It started working again spontaneously after a few months.
Now the brake lights don't work reliably, unless I hold the turn signal position slightly forward when I press the brakes.
Something buggy here, I think.
CTRACY
  • 5 POSTS
I have a 1995 chevy lumina with no brake lights. the 3rd brake light works but the outside (main) lights do not. I saw a post in here about it but couldn't tell what was reccommended to fix it and if it was successfull. The headlights and turn signals work. 1995 chevy lumina 4 door 3.1 V6 135,000 miles. so far all wiring looks good. I replaced brake switch and also ran a jumper across the plug that goes to the switch. lights still don't work. Any ideas? Thanks.
CLY
  • 308 POSTS
The problem is in the turnsignal switch. the lower lights run through the switch and the highmount does not. To fix your problem replace the turnsignal switch assembly. Hope this helps.
Cly
CTRACY
  • 5 POSTS
[quote:6fe4762fb3="Cly"]The problem is in the turnsignal switch. the lower lights run through the switch and the highmount does not. To fix your problem replace the turnsignal switch assembly. Hope this helps.
Cly[/quote:6fe4762fb3]
Where can I find info on removing and reinstalling the airbag (safely)? Thanks.
CLY
  • 308 POSTS
As far as removng the air bag just make sure and disconnect the battery and pull the airbag fuse and you will be fine....
Cly
BDAMERST1974
i have replaced the switch, bulbs, and fuses what else could it be to make the brake lights work
MASTERTECHTIM
  • 4,750 POSTS
do your turn signals work in the rear? if they dont then suspect turn signal switch. does the third brake light work?
BDAMERST1974
yes my turn signals and third brake light works
MASTERTECHTIM
  • 4,750 POSTS
i would suspect the turn signal switch for sure. the brake light switch runs through the turn signal switch so you can have turn signals and brake lights at the same time. its not uncommon for these to go bad. hope this helped
MHERN1
brake lights not working i tested the orange wire at the switch and the white one. power to orange none to white one. bulbs good.
HMAC300
  • 48,601 POSTS
if you are not getting power to the white wire then that is the one that goes to brake lights so your switch is probably bad or out of adjustment see pic.. but also check the dark green and yellow wires leading formt/s switch if no power there then the t/s switch is bad . but before doing that replace the brake light switch.
MHERN1
resend pic please
MELCHRISCAN
The brake lights do not work on our car if the driver is going straight. If turning right the turn signal and left brake work like normal. If turning left, the left turn signal works but no right brake light. The bulbs are fine and so is fuse. Other ideas? The car is 1995 Chevy Lumina. Thank you.
JDL
  • 16,098 POSTS
Does the high-mount brake lite work ok? The lower brake lites are wired throught the turn signal switch, turn/stop use the same bulb filament, just not at the the same time. The wiring diagram is below, check for voltage on the proper circuit, when problem is ongoing. Brown wire is voltage for tail lamps, black is ground, the other color is stop/turn.
MELCHRISCAN
The high mount brake light has not worked for a while but the wife just told me that.
JDL
  • 16,098 POSTS
That might just be a bulb? On the other issue, if no voltage on that circuit when there should be, I'd have to track the circuit back to the turn switch. There is usually a multiwire connector under the dash, close to steering column for wires going into and from the steering column, you can check voltage there. You may need to disarm air-bag, just in case.
MELCHRISCAN
Thank you!
DKLEINJR
I have a 95 chevy lumina and my brake lights quit working on me. The tail lights, hazard lights and turn signals are working but the brake lights are not, including the 3rd light in the rear window. I checked the fuses and there all fine any other ideas what i can do to try to fix this? The shops here are closed and i need the vehicle for the weekend for work.
JDL
  • 16,098 POSTS
Maybe an issue with brake switch, check feed/voltage to and from the brake switch.
JDL
  • 16,098 POSTS
Hope you got it going your way.
JDL
  • 16,098 POSTS
To add, At the brake switch, orange wire is hot all the time. White wire goes hot when the switch is activated.
DKLEINJR
Ok, is this the fuse block in the car, passenger side or drivers side? Also where exactly is this switch located if it is that. And could it just all of a sudden go bad because of a accident? They stopped working when my girlfriend was backing out of our driveway and was constricted of field of vision from a snowbank and someone struck her in the rear drivers side bumper area. It tore down the bumper cover a little but that is really the only damage done to the vehicle. The wires leading to the brake lights are exposed in the crack of the bumper cover but there looks to be no cuts or breaks in the wires, and even so I do not see this making the rear window brake light stop as well. I am looking at the auto part stores listings for switches and they come up with Parking Brake Switch and Stoplight Switch, which of these is the correct switch in witch you speak of?
Thanks for the help you have already given me and I greatly appreciate anymore you can give.
