1995 Chevy Lumina coolant leak and oil light
CRAPLUMINA
  • 1995 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 169,000 MILES
My oil light has been flickering on and off when I am at a stoplight and it idles under 1x1000 now I have an coolant leak and it goes through a bottle of coolant in 4days it not leaking out of my radiator its more of the right side of the engine what is it and how much will it cost for me to replace
Saturday, January 30th, 2010 AT 1:42 PM
ERNEST CLARK
  • 1,730 POSTS
Have you checked the oil level? If it's too low, the oil sender will see low pressure and set the light.
As for you coolant, your description is kind of confusing. Can you actually see where the coolant is leaking from?
If so, you'll have to describe to me what/where it's leaking from. Then I can tell you what part that is and how much it'll cost you in labor/parts.
Monday, February 8th, 2010 AT 8:25 PM
