1995 Chevy Lumina CAR STALLED
ROBERT HUNSAKER
  • 1995 CHEVROLET LUMINA
Electrical problem
1995 Chevy Lumina 6 cyl Front Wheel Drive 143200 miles
CAR RADIO WAS MAKING CLICKING SOUNDS COULD HEAR ACCELERATION ALSO THOUGH THE RADIO DURING OPERATION THEN CAR QUIT RUNNIG WOULD NOT START UNTILL LATER WOULD RUN WITH SAME SYMPTOMS, TURN CAR OFF BUT WILL GET NOTHING BUT CLICKING FROM CYLAINODE AS IF A DEAD OR LOW BATTERY. BATTERY IS UNDER ONE YEAR OLD. NOTE ALSO FRIST TIME NOTHING FROM THE CAR WHEN I TURN THE KEY UNTILL SECOND TRY ONE HOUR LATER. THANKYOU BOB
Tuesday, June 29th, 2010 AT 7:52 PM
INTERNETMECHANIC
  • 700 POSTS
Use a digital multimeter across battery posts, everything turned off. The generic spec for a fully charged battery is 12.6 volts. Leave the leads hooked up at the battery, turn key to crank, does the voltage reading react? Another issue could be a security system, where applicable.
The purple wire at the starter solenoid S terminal, should be hot with the key in the crank position. Is it, if not back-track the circuit. With an automatic, that circuit is wired through the neutral switch.
Wednesday, June 30th, 2010 AT 3:15 PM
