Check the EGR VALVE it might have something to do with your cars problem if the valve isn't opening it will keep stalling hope it helps and fyi if there was water in your sistem it would fail all the time not after it ran a while and the fuel pump is working fine but to be sure get the preassure of the pump checked best regards
SPONSORED LINKS
Tuesday, September 18th, 2007 AT 12:13 AM
