1993 Chevy Lumina car
SABINEPHIL
  • 1993 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 180,000 MILES
My Question is why does my 93 chevy lumina start up and run for a few minutes then stall, and I cannot start it back up for a while. But after a couple of hours it will do the same. Fuel pump works, no obd1 codes, good fuel pressure, new spark plugs, no defects in charging system, i've tried "heat" for watery gas, and fuel injection cleaner. What alows it to start back up after a while
Saturday, January 5th, 2008 AT 5:34 PM
MASTERTECHTIM
  • 4,750 POSTS
When it dies you need to check for spark. If you lose spark you have a bad crank sensor or a bad ignition module.
Saturday, January 5th, 2008 AT 5:47 PM
