1993 Chevy Lumina
PRANGER
  • 1993 CHEVROLET LUMINA
  • 6 CYL
  • 95,000 MILES
Once every couple of days suddenley my check engine light comes on, the car starts to stumble and then dies a minute later. It has done this will stopped and while driving at normal speed. I try to start it, it cranks but will not turn over. I let it sit for a few minutes and then it will start. Then it usually does not happen for a few more days.
Tuesday, April 21st, 2009 AT 2:04 PM
BLACKOP555
  • 10,371 POSTS
Since your check engine light on the first thign to do is take the vehicle in and get it scanned. Autozone and a few other autopart stores will do it for you. If you dont have that convenice take it to a mechanic and have it scanned for codes. But it will cost you a bit.
Post teh codes back here so I can help diagnost your problem without guessing. Saving you money.
Wednesday, April 22nd, 2009 AT 8:03 PM
PRANGER
Thank you for responding. I took my car down to the auto parts store today and had them scan for the codes. It came up with several.
32 - Digital EGR circuit
43 - Knock Sensor/
TPS out of adjustments
53 - Alernator voltage
66 - A/C Pressure sensor
It seems from these that I would need to change the Throttle Position Sensor. It seems to line up with my problems.
Tuesday, April 28th, 2009 AT 1:54 PM
