1993 Chevy Lumina engine cutting out
BCHHTA
  • 1993 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 155,000 MILES
I am having a problem with the vehicle cutting out. When the engine is cold, it will start fine. It drives about 1/4 mile and starts cutting out. It backfires and then eventually dies where it then becomes a nightmare to start up again until it cools off. I have changed the map sensor, plugs and wires, coil packs and ignition module, air intake sensor, and water temp sensor without luck. Any suggestions?
Tuesday, September 1st, 2009 AT 8:04 PM
BCHHTA
Forgot to mention that the fuel pressure was checked and was fine at 38 and also the EGR was changed too. PLUS, there are no codes/check engine light. HELP!
Wednesday, September 2nd, 2009 AT 12:07 AM
LEGITIMATE007
  • 5,121 POSTS
Ok, I would check the catalytic convertor and the crank position sensor, It also sounds like your having some kind of restriction going on here, let me know your findings
Wednesday, September 2nd, 2009 AT 6:49 AM
BCHHTA
Is there a special way to check the cps? I have found it and it looks like a chore to get at. I have a meter and know how to use it!
Wednesday, September 2nd, 2009 AT 7:04 AM
BCHHTA
Replaced the CPS and checked the CC. Still no luck!
Saturday, September 5th, 2009 AT 10:39 AM
LEGITIMATE007
  • 5,121 POSTS
So if you fuel and spark is good, then there is air restriction, check cam sensor, compression, and knock sensor.
Sunday, September 6th, 2009 AT 9:12 AM
