1992 Chevy Lumina Oil in the Radiator
250,000 MILES • 6 CYL • FWD • AUTOMATIC
TOECUTTER
There is an oily sludge that collects on the radiator cap over a period of 4 days or so. The oil looks low on the dipstick but no foam or froth is on it. The oil is clean. Is this indicative of a blown head gasket?
Apr 27, 2009 at 1:23 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:5a82b0731b="Toecutter"]Engine Cooling problem
1992 Chevy Lumina 6 cyl Front Wheel Drive Automatic 250000 miles
There is an oily sludge that collects on the radiator cap over a period of 4 days or so. The oil looks low on the dipstick but no foam or froth is on it. The oil is clean. Is this indicative of a blown head gasket?[/quote:5a82b0731b]
Yes, it is.
But,
What color is the sludge and does it smell like Oil or Tranny Fluid?
Apr 27, 2009 at 1:32 PM
TOECUTTER
It's not very dark sludge, like a coffee w/cream color. The smell is sort of hard to tell, doesn't really smell like oil OR tranny fluid. Almost looks like some sort of grease by the consistency of it.
Apr 27, 2009 at 1:45 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:0cd6316344="Toecutter"]It's not very dark sludge, like a coffee w/cream color. The smell is sort of hard to tell, doesn't really smell like oil OR tranny fluid. Almost looks like some sort of grease by the consistency of it.[/quote:0cd6316344]
Ok, I am pretty sure it is the head gasket.
You say the oil was low when you first noticed the problem. Have you filled it or just noticed the oil was lower each time.
If not have you checked the tranny fluid?
Apr 27, 2009 at 2:50 PM
TOECUTTER
Transmission fluid is good, checked that 3 days ago. Just the oil is about 1/4 to 1/3 down from the top mark. I'll fill it and monitor.
Apr 27, 2009 at 3:24 PM
TOECUTTER
Yes, it appears that the oil that is getting into the rad. Topped the oil up and cleaned the rad cap off. 5 days later and the oil is down a bit and the rad cap has more gunk on the inside of it. Though the gunk may have already been in the cooling system prior to me topping the oil up.
May 4, 2009 at 5:40 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Sorry for delay in responding,
Ok, sounds like you do have a blown head gasket. And it seem link a small leak right now however, it won't take long before it becomes a big leak and problem so the sooner you can get it fixed the better.
May 7, 2009 at 3:00 AM
