1992 Chevy Lumina coolant leak
128,500 MILES • 6 CYL • FWD • AUTOMATIC
MAURICE POOR
car got close to red line on gauge and now coolant leaking out a hose on firewall,it was never hooked up to anything and i was told it was a bad heater control valve,is this true,if so why would that leak coolant?
Dec 16, 2008 at 5:20 AM
JALOPYPAPA
  • 467 POSTS
Some cars have a control valve that turns on and shuts off the flow of coolant to the heater core through those hoses on the firewall. However, I think this car lacks such a valve and the heater is controlled only mechanically by the ductwork door, i.e., coolant flows through the heater core all the time. Coolant can leak from the hoses; from the valve, if equipped; really from just about anywhere. At any rate, if you don't get it fixed, you'll probably be back at that red line soon.
Dec 16, 2008 at 6:40 AM
