1992 Chevy Lumina 1992 Chevy Lumina - No Start, No Spark
ZHAMMER
  • 1992 CHEVROLET LUMINA
  • 6 CYL
  • FWD
  • 152,186 MILES
The car is a 1992 Chevy Lumina Euro - 6 cylinder 3.1 liter engine.
I am a bit of a newb with most of this stuff - but I can at least tell you what I have done so far.
After a weekend in the garage (friday evening to monday morning) without taking it out - the car wouldn't start.
I've had problems with the car not starting due to the cold, but it would start if I it got warm enough - that did not work this time.
A few weeks ago the fuel filter was replaced. About a year ago the fuel pump was replaced (and I have been told by my father in law that it sounds like it is working - he turned the key and listened for a sound).
I have tried replacing the front three spark plugs (I can't figure out an easy way to get to the back three).
My father-in-law and I tested to see if it had spark and it didn't.
I sprayed some throttle body cleaner in the throttle body (by recommendation).
I tested all the fuses I could find (found set that covered things like "ignition" and stuff, another set that covered lights mainly, and a set in the glove box that covered stuff inside the cabin) and they were all okay.
Used a computer scanner and got these error codes with these messages:
22 - throttle position sensor is too low
35 - idle speed error
45 - oxygen sensor rich
44 - oxygen sensor lean
At this point I am not too sure what I should do or check.
Let me know if you have any questions that I can answer.
Monday, March 1st, 2010 AT 6:23 PM
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it -Get back with some testing results
Tuesday, March 2nd, 2010 AT 12:01 PM
