1991 Chevy Lumina NO INJECTOR PULSE
HOTTRODD1957
Engine Mechanical problem
1991 Chevy Lumina 6 cyl Front Wheel Drive Automatic
HELP NO INJ PULSE
Mar 17, 2010 at 4:52 AM
JDL
  • 16,098 POSTS
Hi, your saying, with engine cranking, there is B+ at the injector, but no ground? If that is the case, maybe the computer doesn't see an rpm signal? Engine cranking, you have good spark at all the plugs and fuel pressure is proper specs?
Mar 17, 2010 at 9:14 AM
