Does it die at idle or only in gear?
Pressing the schrader valve to see if gas squirts up, isn't the best way. You would have an initial prime when you turn on the key, no crank. You need to see if the fuel pump is running, with the engine cranking. You can turn the key on, no crank, leave the key in the on position, wrap something over the schrader valve, so gas doesn't go everywhere, bleed the pressure off, then, without recycling the key, crank the engine for a few seconds, recheck the schrader valve to see if there is any pressure. You have to do the testing when the vehicle refuses to start. My first thought was, you may be losing the rpm signal. With the engine cranking if there is no rpm signal, you will have no spark at the plugs, no injector pulse. Other than the initial prime, the pump won't run, unless there is an o/p switch in the pump circuit. I don't believe you have that.
Tuesday, July 29th, 2008 AT 10:13 AM
