I'd use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage. The fuel pressure for the 3.1 is 41--47 psi. Also, check for applicable mil codes. The throttle position sensor is at the throttle body, attaches to the throttle shaft. Your accelerator cable attaches to one end of the throttle shaft.
SPONSORED LINKS
Thursday, October 7th, 2010 AT 10:14 AM
