1990 Chevy Lumina Ignition module
1990 CHEVROLET LUMINA
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
EMBALMER97
My 1990 Lumina is starting to sputter after it runs for about 50 miles. It starts good, doesn't use any oil. All in all it is a good car except for this one issue. After it cools off it will start just fine until it is run another 50 miles or so. The plugs and wires have been replaces.
May 26, 2008 at 1:01 AM
MERLIN2021
  • 17,250 POSTS
Your symtoms can be the module, or EGR sticking, or fuel pressure...is the service engine light on or flashing? test for stored codes this way.
https://images.2carpros.com/forum/automotive_pictures/62217_95_OlderGM_24.jpg
Cross these two terminals as shown, then turn the key on. Count the flashes, a 22 will flash as 2 flashes then a short pause, then 2 flashes, if more than one code is stored, the pause will be longer. The codes will display three times and end with 12. Write them down and post here. This connector is right under the middle of the dash...
May 26, 2008 at 1:38 AM
