1990 Chevy Lumina
BIGMAN73
  • 1990 CHEVROLET LUMINA
Engine Performance problem
1990 Chevy Lumina 6 cyl Front Wheel Drive Automatic
My lumina will crank over but will not stay started.I put a new fuel filter on and drove it around the block, at first it ran great, but then it died on me when I got almost around the block. So then I thought it my be the fuel pump, so I took off the fuel line from the engine and turned on the key and the fuel came out great. So what could be the problem?
Wednesday, April 29th, 2009 AT 12:46 PM
JDL
  • 16,098 POSTS
Hello, Maybe your intermittently losing the rpm signal. When the problem occurs have a helper crank, while you check for spark at the plugs and injector pulse. Any codes?
Wednesday, April 29th, 2009 AT 12:58 PM
BIGMAN73
No codes.
Wednesday, April 29th, 2009 AT 1:20 PM
