Where is the fuel pressure regulater sensor at on this car.
Jun 16, 2007 at 12:01 PM
DWANA
MEMBER
1 POST
How do you change coil packs on a 1991 lumina? Is there somewhere i can find a diagrammed break down so i can see exactly how to remove the old one and put the new one in. Thanks. Dwana.
Jul 10, 2007 at 11:39 AM
JEFFROHOTROD
MEMBER
The fuel pressure regulator is located underneath the intake plenum. To change the coils the is a bolt at the top and bottom of each coil and 3 wiring connections on the control module that is behing the coils. There is a firing order on the body right above the radiator.
Jul 11, 2007 at 4:01 AM
