if someone has any ideas it would be grate if you could give me a few pointers.
thanks
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
If faced with a similar breakage, have the remaining plug and cylinder-head condition assessed before choosing an extraction method. Confirm that the threads and cylinder are free of damage or debris before returning the engine to service.
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis.
Remove the remaining hollow threaded spark-plug shell with a screw extractor (easy-out), which the owner confirmed worked. To help prevent plugs from snapping, replace them before they seize, use anti-seize on the threads, and stick with the plug type specified for the engine.
A driver said a spark plug broke during removal, leaving the threaded steel shell in the cylinder head, and asked how to get it out without disassembling the engine. Another member suggested a screw extractor after clearing any remaining porcelain, and the owner later confirmed that method worked. The discussion then turned to plug brands, with some blaming thin Bosch shells. The expert said plug choice depends on the engine, recommended staying with the original specification, and noted that earlier replacement or anti-seize on the threads can help prevent breakage.
spark plug snapped
A spark plug broke during removal, leaving its threaded portion in the cylinder head after the hex broke away. The owner later reported that a screw extractor removed it successfully.
Reported outcome: The owner reported successful extraction.
The thread does not document a post-removal inspection or engine-running result. Suggestions to chip ceramic or force a screwdriver into the remains, and broad plug-brand claims, are not adopted.
