1992 Ford Ranger Oil Pressure Drop
PIKAP417
i have a 92 ford ranger with 172,000 miles on a 2.3l engine. last week i changed the oil and the following day after about a half our drive i lost all oil pressure. the valves started to chatter, iput another oil filter on it and it was fine for about another 20 min. drive then the oil pressure was erratic and finally drooped all the way off. is this definately an oil pump or should i look elsewhere first?
Jan 8, 2006 at 4:23 AM
DB554
  • 35 POSTS
take your oil filter off and check the egine block the oil filter screws on make sure the old oil filter gasket is not still on there if it is it will cause the oil to leake out! I know it sounds simple but i have seen it happen quite often good luck
Jan 8, 2006 at 7:26 AM
Suggested Repair
Remove the oil filter and inspect the filter mounting surface on the engine block. Confirm the old filter gasket is not still stuck there, since a leftover gasket can cause oil to leak out and oil pressure to drop.
Conversation Summary
The owner of a 1992 Ford Ranger with a 2.3L engine and 172,000 miles lost oil pressure after an oil change; pressure briefly returned with another filter, then became erratic and dropped again. The expert recommends first checking that the old oil filter gasket did not remain on the engine block, which can cause oil leakage.
