i changed my radiator ,fans . but my low coolent light stays on , coolant is level. 2000 chevi impala 3.4 v6 93.000mil.
Aug 30, 2007 at 1:02 AM
Confirm the coolant is actually full, then test and replace the coolant level sensor if it is faulty.
The owner of a 2000 Chevrolet Impala 3.4 replaced the radiator and fans, but the low coolant light stays on even though the coolant level is full. The expert says the coolant level sensor is most likely bad and that the light is otherwise caused by actually low coolant.
