BUBBAGUMP
I have a 2000 Ford Ranger. My rear lights (tail lights and license plate lights do not work). I replaced the bulbs and they still do not work. Also, my dash lights are out and the idiot chime does not go off when I leave the headlights on. I checked all my fuses and none of them are blown. I do not know what to check next. A friend of mine said to look at the ground wires, but I do not know where to find all of the ground wires. Any suggestions would be appreciated.
Jan 3, 2006 at 12:32 PM
DELTA1988
  • 5 POSTS
you should look at all the wires from the ass end of your truck right under your dash. sometime they get cut broken connections along the way. I had to do that a few times and found that there were some places that were broken. now for the ground wires. what i would do is make new ones. then you would know for sure that its all good for the ground.
Jan 4, 2006 at 1:04 PM
