2002 Chevy Impala Wipers Won't Park
ARIELTHESPRITE
The windshield wipers on my Impala are in the up position when they are off. They work fine otherwise just that they don't reset in the correct down position. What is the problem with it? How do I fix it?
Thanks
:lol:
Jun 13, 2007 at 6:12 AM
SERVICE WRITER
  • 9,123 POSTS
You can eliminate the switch by turning on the key to run, not start. Turn the switch for the wipers to on and then disconnect the harness to the switch. If they return to the normal park position you need a switch. If it doesn't, There is a procedure that you can continue going through, but in my experience it is almost always the wiper control module. Napa sells them with the motor.
Jun 13, 2007 at 7:29 AM
Suggested Repair
With the key in run, turn the wipers on and disconnect the switch harness. If they park normally, replace the wiper switch. If they do not, replace the wiper control module, which is commonly sold with the motor.
Conversation Summary
The owner of a 2002 Chevrolet Impala said the windshield wipers work but remain in the up position when turned off instead of parking down. The expert recommended a switch disconnect test and said that if the wipers still do not park, the wiper control module is the usual cause and is available with the motor.
