Leaking tranny pan
IMPALASAM
I changed my transmission filter and gasket the other day and it has been leaking a little. Is it because I didn't use any cement on the gasket? Or do I need to tighten the bolts?
Jul 18, 2007 at 1:19 PM
CLY
  • 308 POSTS
I dont recomend using gasket maker on transmission pans. The most likely cause is that you have over tightend the bolts and have damaged the gasket.....
Cly
Jul 18, 2007 at 11:25 PM
