2004 Chevy Impala Transmission Fluid
DHMARATHON
I have a 2004 Impala with 47000 miles, easy driving, mostly highway, 16000 mi/yr. Dealer tells me transmisssion fluid is changing color and should be changed. Manual says 100,000 miles unless driving conditions are severe which does not fit my driving. Have others seen this on 04 Impala?
Jul 26, 2007 at 6:00 AM
CLY
  • 308 POSTS
I know what they say the servicing intervals should be but I would suggest it be serviced at 50,000. It is just protecting your investment. They say that you dont have to change the oil on GM cars until the change oil soon light comes on. I have seen cars come in the shop for there first oil change at 12,000 miles. Would I recomend that..NO WAY.....It is totaly up to you....
Cly
Mar 17, 2021 at 8:49 AM
Suggested Repair
Have the transmission fluid serviced around 50,000 miles as preventive maintenance, even if the manual lists a longer interval, especially if the fluid is changing color.
Conversation Summary
The owner of a 2004 Chevrolet Impala with 47,000 mostly highway miles was told by a dealer that the transmission fluid is changing color and should be changed, although the manual lists 100,000 miles under normal driving. The expert recommended servicing it around 50,000 miles to protect the transmission, while noting the decision is ultimately the owner's.
