Chevrolet Impala Transmission Pan Leak
IMPALASAM
I changed my transmission filter and gasket the other day and it has been leaking a little. Is it because I didn't use any cement on the gasket? Or do I need to tighten the bolts?
Jul 18, 2007 at 1:19 PM
CLY
  • 308 POSTS
I dont recomend using gasket maker on transmission pans. The most likely cause is that you have over tightend the bolts and have damaged the gasket.....
Cly
Jul 18, 2007 at 11:25 PM
Suggested Repair
Do not use gasket maker on the transmission pan. The leak is most likely from overtightened bolts that damaged the gasket, so replace the damaged gasket and avoid overtightening the bolts.
Conversation Summary
A Chevrolet Impala owner reports a small transmission pan leak after changing the filter and gasket and asks whether gasket cement or tighter bolts are needed. The expert advises against gasket maker and says overtightened bolts most likely damaged the gasket.
