Front Brakes 2003 Chevy Impala
176SUPERTECH
  • 5 POSTS
I have a 2003 Chevy Impala (53K miles) with a front brake problem. When I brake, the left front brake pulsates which can be felt in the brake pedal.The harder the brakes are applied, the more it pulsates. I have replaced the front pads and rotors, bled the brakes and replaced the front tires. None of these helped. Could it be the caliper or antilock brakes? The car stops OK and the brake pedal does not go to the floor.
Mar 7, 2006 at 9:40 AM
NOS
  • 320 POSTS
warped drums or rotors on the back may cause same problem. most generally if it is abs problem it will set abs light. (NOS
Mar 8, 2006 at 4:08 PM
