1996 Nissan Sentra Check Engine Light Stays On
JBG
the rear oxygen sensor on my 96 Sentra broke. When it broke the check engine light went on. I replaced the sensor but the light won't go off.
Jan 4, 2006 at 10:19 AM
FISHERMAN
  • 937 POSTS
I think you have to use the scanner to reset the computer, I used to have the same problem whit my Maxima, just go to the nearest autozone and rent (for free) the scanner tool, connect the arness to the diagnostic port and read the codes stored on your computer, after that, delete them.
Its simple!
Hope it helps.
Manuel.
Jan 5, 2006 at 1:26 AM
Suggested Repair
Rent a free scan tool at AutoZone, connect it to the diagnostic port, read the stored codes, and clear them to reset the computer after the rear oxygen sensor replacement.
Conversation Summary
The owner of a 1996 Sentra replaced a broken rear oxygen sensor, but the check engine light stayed on. The expert advised using a free rental scanner at AutoZone to read the stored codes and delete them to reset the computer.
