Chevrolet Impala Stalls at Stop Signs
DYTNMANN
i bought it used. It shows the Brake sign on the screen. I took her to the mechanic also but he said the brakes are fine don't know why the sign is on. But the main problem is that, it would start fine in the morning, and cuz its cold so i just warm the car before moving it. It would run fine for some time but when i slow the speed at a stop sign or to take turns after slowing down from 45 or more than that it starts jerking and stalls. I don't know what the problem is. Would tuning up fix it. Please help.
Jan 6, 2006 at 3:30 PM
FOLEY34
I would check the distributor cap and rotor--any carbon cracks would stall the engine at unforseen tiimes. It has not happened in my own Toyota but did occur on my 82 Ford pickup. The dealer could not find the problem. I found a bad rotor cap by accident and replaced and cured the problem.
Mar 1, 2006 at 4:23 AM
KGOPEL
  • 13 POSTS
I'd check your EGR valve.
Mar 12, 2006 at 5:32 AM
  • 75,988 POSTS
EGR sounds good and a good Throttle Body cleaning.
Mar 15, 2006 at 10:35 PM
Suggested Repair
Check the EGR valve and clean the throttle body.
Conversation Summary
The owner of a used car reports that it starts and runs after warming up, but jerks and stalls when slowing for stop signs or turns from higher speeds. A brake warning is displayed, though a mechanic found the brakes themselves fine. Replies suggested checking the distributor cap and rotor for carbon cracks and checking the EGR valve. The expert agreed with checking the EGR valve and recommended a thorough throttle body cleaning.
