Bmw 318i 02 Crankshaft sensor
1931 CHEVROLET IMPALA
BRODZ
I bhought my 02 Bmw 318i in August last and since then have some problems with it cutting out at road jucntions when coming to a stop after going down through the gears, having it seen to at the moment have been told it could be the crankshaft sensor?
I have also been reading some of the car reviews on this model and have found it can be a problematic car for what is supposed to be the ultimate driving machine, some of the smaller problems i have encountered is the interior mouldings creaking whilst driving and not neccessarily on rough surfaces.
If anyone has encountered the above can they tell me how they rectified the problems
Thanks :?:
Jan 6, 2006 at 12:50 PM
  • CERTIFIED EXPERT
  • 53,877 POSTS
First scan the PCM for trouble codes using a hand held scanner, Then repair codes by replacing failed sensor as needed. If no codes are present, try replacing the idle air contol motor
Jan 10, 2006 at 1:24 PM
