2003 Chevrolet Impala Driver AC Warm
DAMIEN PLUNKETT
I have an 2003 impala with 124000 miles and 3400 engine. I recently had refrigerant added because was not getting cold it worked fine for a few weeks and then all of a sudden now it only gets cold on passenger side .I have dual climate control but it only gets hotter if i move it up but doesnt get cool at all just blows hot air can anyone help me with this problem.
Aug 10, 2007 at 7:34 AM
DENNYP
  • 1,824 POSTS
[quote:e390f327a5="damien plunkett"]I have an 2003 impala with 124000 miles and 3400 engine. I recently had refrigerant added because was not getting cold it worked fine for a few weeks and then all of a sudden now it only gets cold on passenger side .I have dual climate control but it only gets hotter if i move it up but doesnt get cool at all just blows hot air can anyone help me with this problem.[/quote:e390f327a5]First you need to have the A/C system leak tested.If it has low charge,the pass side will cool but the driver side will be warm.
Oct 1, 2007 at 1:53 PM
Suggested Repair
Have the A/C system leak tested. A low refrigerant charge can cool the passenger side while the driver side stays warm.
Conversation Summary
The owner of a 2003 Chevrolet Impala with dual climate control said the A/C was recharged and worked briefly, then only the passenger side stayed cold while the driver side blew hot air. The expert advised leak-testing the system because low charge often cools the passenger side while leaving the driver side warm.
