2002 Chevrolet Impala AC Floor Water
JIMBOG
I am getting water on the passenger floor when I run the AC . Where exactly is the evaporator drain line located on a 2002 impala. do you have to be under the car to get to it.
Thank you much.
Oct 15, 2007 at 11:06 AM
  • 75,988 POSTS
[quote:b5abe89dbf="jimbog"]I am getting water on the passenger floor when I run the AC . Where exactly is the evaporator drain line located on a 2002 impala. do you have to be under the car to get to it.
Thank you much.[/quote:b5abe89dbf]
Could be underneath the car or its in between the engine and firewall at the front passenger side.
Might also want to clean the cabin air filter
Oct 19, 2007 at 12:38 PM
Suggested Repair
Check the evaporator drain under the car or between the engine and firewall on the front passenger side, and clean the cabin air filter.
Conversation Summary
The owner of a 2002 Chevrolet Impala reports water on the passenger floor when the AC runs and asks where the evaporator drain is and whether it is accessed from under the car. The expert says it may be under the car or between the engine and firewall at the front passenger side, and also suggests cleaning the cabin air filter.
