Thank you for this post I had this problem a followed the guide worked perfect! I love this site.
Sep 13, 2019 at 3:40 AM
ELAINE0358
MEMBER
1 POST
I get an engine power reduced and engine light comes on. I have had a new throttle put in along with a new engine with 63,000 miles and it was good for one day and the reduced engine light came on again while driving. The garage has tested everything and not coming up with the problem. Is it electrical or why is GM not dealing with this problem as it appears that it has been a big issue!
Sep 19, 2020 at 7:27 AM
(Merged)
✓Experienced Mechanic
Reduced power, AKA limp mode, is actuated when the computer determines there is a major problem with the vehicle. Not only the engine can cause it, but also a transmission issue. If they are getting no trouble codes, it sounds like an electrical problem, but it could be a number of things.
(Merged)
AARON HALL
MEMBER
1 POST
Wellllllll, went to my college town one day and out to lunch with a friend. Came out of the restaurant and tried starting my car, but it wouldnt start. The dashboard said "engine reduced power'' and something about the servicing the traction control. The engine actually shut down while trying to put it on the tow truck. Now the car wont start and we have no clue as to why. Even when we try to jump it, its not starting. How do we remedy this situation?
(Merged)
Good morning
First, it sounds like the battery may be low. Low voltage is the main reason for things not working all at once and not starting.
daughter was driving car and said engine light came on then the message said "engine power reduced". Then she said it was like she could barely go 60 mph.
(Merged)
Have the computer scanned to identify where the problem came from. Ask if the engine was overheating or anything, other than the reduced power, occurred.
(Merged)
WRENCHTECH
That is going to be a problem with the "drive by wire" electronic throttle system. The first step will be to read codes but you will need some expensive equipment to get a final diagnosis.
(Merged)
LEESSA16
MEMBER
1 POST
My car acts like it is in limp mode. Codes po300 and co561 traction service lights comes on and engine light flashes.
(Merged)
HMAC300
300 is a random misfire which are very hard to diagnose even for a mechanic before you waste any money the cheapest option is for him to fix it. the code 561 is an ABS code which knocks off the traction control. It may be a serial BUS problem or the engine code may have set it. a mechanic will need to check this out.
(Merged)
ROZYRY
MEMBER
I was leaving work and I went to start my car and it seemed like the battery was almost dead. I turned it on and 'engine power reduced" came on and the motor sounded like it wanted to jump out! The RPMs where jumping up and down. I know I need an oil change, but my car was running fine. before. I've noticed an oil leak the past few weeks and I thought maybe the oil filter was loose(I was told). I turned it on again about 3 more times and same thing! So I called for my boyfriend to come and by the time he came (20 min) I started it again and it turned on fine. The engine light was on though. I drove home (which is 25min drive) and it drove fine. I don't understand, I don't want that to happen when I go to work. I checked the oiland it was at an ok level...
Sep 19, 2020 at 7:28 AM
(Merged)
SATURNTECH9
The first thing you need to do is go to a auto part's store and have them scan the car for trouble code's and write down all the code number's your car has and bring them back to me.
(Merged)
CAROLANDOH
MEMBER
1 POST
Engine Performance problem
2006 Chevy Impala 6 cyl Two Wheel Drive Automatic
repair and cost
(Merged)
MMPRINCE4000
Take car to most autoparts stores and get codes read for free.
If so, it may simply require a simple cleaning as was the case above.
(Merged)
BILLYBLAIRJR
MEMBER
1 POST
06 chevy impala will read engine power reduced service traction control. You can turn car off and wait 15 min start car back up everything runs normal for a little while then same thing. please help
(Merged)
RHALL77
trhere is trouble code stored in the pcm that needs to be check. your car is going into default mode to prevent any further damage.
(Merged)
NEIL WILLIAMS
MEMBER
When the engine is at 3,500 rpm and when I push the gas pedal down some more, the rpm stays at 3,500 rpm.
(Merged)
I assume this is in neutral? If so the computer will not allow the engine to rev above 3,500 so the engine does not hurt itself.
Please let us know.
Cheers, Ken
(Merged)
NEIL WILLIAMS
MEMBER
No. In park.
Thank you for your reply.(answer).
(Merged)
Park will do the same thing :)
Please use 2CarPros anytime, we are here to help. Please tell a friend.
Cheers, Ken
(Merged)
NEIL WILLIAMS
MEMBER
Thank you for your answer. I thought it was something serious.
I am so relieved!
Thanks again, Ken
(Merged)
BOBBII DAVIS
MEMBER
My car starts but does not move when i press the gas in drive, first or third gear. it only revs the engine, but it reverses and drives slowly in first gear.
(Merged)
SATURNTECH9
Are there any codes in the computer? Also what does the transmission fluid look like?
(Merged)
BOBBII DAVIS
MEMBER
I checked it it is empty could that be the problem?
(Merged)
BOBBII DAVIS
MEMBER
But it just happen so I do not know if there are any codes, but the check engine pops up and stays on when I turn the car to on but goes off when I start it.
(Merged)
SATURNTECH9
There is no fluid in the transmission? You can see leaking fluid? Yes that is normal for the check engine light to be on then turn off when the engine starts?
(Merged)
BOBBII DAVIS
MEMBER
No leaking fluid beside my power steering because there was a defected one put on when I went to get it fixed and no there is no transmission fluid.
(Merged)
SATURNTECH9
If there is no fluid in the transmission the transmission wont work correctly and the car wont move. Plus without fluid in the transmission it will be severely damaged. Question is if there are no visual leaks where did the fluid go?
(Merged)
BOBBII DAVIS
MEMBER
in February my car stopped working and was sitting until the Beginning of this month we juat started driving and we haven't put anything since before it stopped working
(Merged)
SATURNTECH9
So what happened to the car in February that it had to sit all this time?
(Merged)
NEIL WILLIAMS
MEMBER
I get a display on the dash that says"engine power reduced."
The only codes that come up are P0106, P0449, P0452.
There are no other codes!
These three codes do not say anything about "engine power reduced."
Please help.
(Merged)
Anytime you have code the engine power will be reduced. You have a BARO and EVAP codes is there any symptoms along with the codes?
Cheers, Ken
(Merged)
NEIL WILLIAMS
MEMBER
The engine is a little hard to start. It cranks a little longer than usual but, when I give it a little more gas, the car runs fine. new fuel pump and fuel filter (under frame).
Traction also shows up on dash. Could the inhibitor relay be defective?
Thank you very much for your reply.
(Merged)
SATURNTECH9
Here is my take on this whole thing. the p0106 is for your map sensor the p0449 is for the vent control solenoid circuit and the p0452 is for your fuel tank pressure sensor. What do all three have in common they all share the same five volt reference signal or five volt power supply to them. I would be checking the fuses under the hood see if any are blown. Also, those codes will not or should not put the car in reduced performance mode. That happens when there is a fault in the throttle by wire system like a fault in the throttle position sensor gas pedal sensor etc. The traction light might be a clue if it is seeing wheel slippage or thinks that is happening then it would retard the timing and cause a reduced performance feel etc.That would take more than a basic diyer code reader to read ABS or traction control codes. I would first looking into those three codes your getting and see where that takes you. Let me know what you find with the fuses if any are blown.
(Merged)
Nice catch Saturntech9.
Here is a guides and some diagrams (Below) of the fuse layout:
Please let us know what you find. I am interested to see what it is.
Cheers, Ken
Images (Click to enlarge)
(Merged)
SATURNTECH9
I would be really looking in the under-hood fuse box at the 15 amp emissions 1 and emissions 2 fuses.
(Merged)
ROOFING12345
MEMBER
1 POST
Mass air flow sensor is disconnected as its not working trying g to save up $200 for a new one how lo g can the car run without it being plugged in and can it cause any long term damage?
Sep 19, 2020 at 7:29 AM
(Merged)
TY ANDERSON
Without the mass air flow sensor the vehicle's computer will default into a preset or pre programmed operating mode. In this mode the vehicle will output more emissions and your fuel economy will be reduced. Other than that you'll probably not have any issues long-term or short-term. I would not recommend driving up any steep canyons or grades just as a precaution.
Thanks for the question
(Merged)
DARK7973
MEMBER
Hello I have a 2000 impal LS with 3800 engine and trans and as the title states I just replaced my old engine and trans with one from a 2003 Monte Carlo SS 3800. First off im showing code p1810. Mainly the trans was working fine when fist ran and now will not go past 2nd gear(LIMP MODE). I unplugged the main trans pigtail ang plugged it back up and it worked fine for a few min then reverted back to LIMP MODE. I have been reading that some things were changed inside the 4t65e trans on 2003+ models. Any ideas???
